This is a test with an Amd Fx55 with 2GB Ocz Pc4000 memory
Does X2@5200 make this much difference, can someone post an Amd Fx55 read, write score with a recent version of Everest please, and or add comment if you wish
With regards to the Core2Duo 6800 score, to achieve similar performance to the 6800 score with an Conroe 6300 you would need to buy the memory below is this right?
G.Skill 2GB DDR2 HZ PC2-6400 (2x1GB) CAS4 Dual Channel Kit (F2-6400PHU2-2GBHZ) (MY-013-GS)
- Package : 2048MB kit (2x1GB) dual channel pack
- CAS Latency : 4-4-4-12 (PC2-6400)
- Test Voltage : 2.0-2.2 V
- Speed : DDR2 800MHz (PC2-6400)
- Type : 240-pin DDR2
Price: £169.99 (£199.74 Including VAT at 17.5%)
Original test was at http://www.driverheaven.net/reviews/OCZPC4000PlatinumEBReview/system.htm
Fx55 score
Fx55 score
