(Yes I bought an AMD FX-8150
Anyway I eventually got it installed in my new PC after a load of problems with every other component.
I downloaded AMD Overdrive and noticed the frequencies of each core were going wild. They must have been changing 10 times a second to seemingly completely random numbers between 1400MHz and 4200Mhz, all independently. I thought there were just 3 fixed frequencies it can run at (3.6, 3.9 and 4.2.)
Secondly I noticed the temperature sensor must be faulty. It too was fluctuating wildy (e.g. it would go from 28 to 14 to 23 to 11, etc.. really fast)
Lastly I noticed the reported CPU voltage was 1.42v! I double checked and everything is set to AUTO in the BIOS. That voltage is too high for this CPU for 24/7 usage.
Do I have a dodgy CPU? I wouldn't be suprised as everything else I bought has been faulty
I will upload screenshots of Overdrive and CPU-Z etc.. later tonight or tomorrow.
)Anyway I eventually got it installed in my new PC after a load of problems with every other component.
