- 23 Sep 2008
Hi,
Started to OC my FX8320 yesterday, Currently I have it running @4.4ghz (x22 ,multi) And about to run a prime test overnight (Ive ran prime for about 2hours, no errors).
Im running it on a Sabretooth 990fx, in the bios I have the VCore showing as 1.296 but when under load its showing 1.308 in CPUZ.
I have LLC at 75%. Is it normal for the VCORE to be doing this? I have it in offset mode, with a -0.0125 adjustment.
Core temp shows a Max of 55.
I've had it stable @ 4.3 with a bios VCORE of 1.284v, under 100% load @1.296v overnight.
Im worried that the temps may be high, and was wondering if im running a good clock, should I be using LLC? There seems to be some debate on this looking around.
I will try to get some screens up later, as it may make more sense. I've only OC'd Intel before and that was some time ago.
