Hi guys, I've just built a new system and having a little difficulty in basic overclock. The board is a MSI 990FXA Gaming, I coupled this with the FX8350, 390 MSI Gaming gpu and 8GB of ram.
I've disabled the usual cpu control settings c&q etc in bios slowly bumped frequency up but noticed the processor immediately required more voltage, after a couple of bumps it BSOD so I upped the CPU-NB voltage a couple of notches and sorted that. Anyway it has hit a stubbling block. 4.5GHZ I'm at 1.5v which does not seem right but its holding stable ish. prime is holding all the cores but the frequency and voltages are crashing. 1400mhz / 1volt. There is no vdroop control on this board and Im wondering if its the board that is cacking itself and not just a poor cpu. The cooler is H90 and the temps have not exceeded 48c
any suggestions cheers
. I have disabled all power saving and trotting settings in bios 2.
. There are a few ripples but it never dropped bellow 100% and cores stayed at 4.5ghz. Voltage is still way to high for my liking. I will try again with this turned off to see if it effects cpu at lower voltages.
