G hub not starting up when pc is turned on
Is it set to run on startup (and failing to open), or is it just not set to run at all? You can check this easily with Autoruns.
Is "Always start after logging in" checked in Menu -> Settings in the G-Hub app? If it is, try unchecking/rechecking it to re-add the autorun entry if it doesn't already exist
Not what you want to hear, but my G-Hub seems to start and not start whenever it feels like it. I gave up trying to fathom it out!! Good luck.
Just download the ghub package and reinstall, it will retain all profiles and should fix this. Happens on my laptop all the time which is on insider builds.
Also found out this no longer works in safe mode as I found out when I tryed to update my nvida driver with DDU installer.
Seems its down to issues with the new rgb feature in the latest Windows.
Winaero tweaker
It has an allow windows installer in safe mode tweak
Though been a while
Since I used it so can't say if it's working
In newer windows version numbers
Thought I would update this thread, logitech have fixed these issues with the latest version of g hub, thank god.
