- 14 Jan 2006
I have just purchased a set of the G.Skill 2GB DDR HZ PC4000 (2x1GB) CAS3 Dual Channel Kit DIMMS. I also have an ASUS A8N-E motherboard (nforce4) with an athlon 64 3500+.
I just do not seem to be able to get the memory to run above 200mhz.
I will completely admit that I am a total n00b when it comes to memory timings etc. But the thing I really wonder about is the following
The fsb of an Athlon64 = 200mhz, ddr400 ram runs at 400mhz.
For the above ram to run at 250 would that mean that I would need to increase the FSB of the system (essentially overlocking the processor from roughly 2.2ghz to 2.7-2.8 ghz) Would I also need to adjust the ram timings due to change in FSB, or am I approaching this problem the totally wrong way?
Many thanks
Callum
Many thanks
Callum
