- 16 Jun 2008
This may be an obvious question, but im not sure whether my theory is correct. I bought some G.Skill 4GB DDR2 PQ PC2-6400C5 RAM for my new build based on a recommendation from a member on here to match the Abit IP35 motherboard. As a comlpete novice to overclocking, i took the advice without much consideration and the reasons presented made sense to the little knowledge i have.
Ive just noticed in CPU-Z that it says its running at 400MHz, with timings of 5-5-5-15, but its supposed to be 800MHz. So is it showing 400MHz because its dual channel and thus i should double it? Or must i overclock to achieve it?
It also states an FSB : DRAM ratio of 2:3.
Ive not started to overclock yet due to working from home and not wanting to stuff up my income. I'm planning to start soon as this project is coming to an end and thus have abit more time to experiment.
Sorry for asking what is probably an obvious question, just trying to get my head around things, ive read through the guides and just need to know how to read/understand the tools im using.
Thanks!
Thanks!
