Before I drop kick my PC out the bedroom window, I'm hoping to try some new RAM... Looking at either:
G.Skill DDR3 4GB kit 1333MHz 7-7-7-21-2N @ 1.5V
G.Skill DDR3 4GB kit 1600MHz 7-7-7-24-2N @ 1.65V
I'm running at stock speeds, so 1333 needed. I like the 1.5V rating of the slower speed. But then again the 1600 will run the same latency at a higher speed (albeit with increased voltage).
How likely can I run the 1600 at 1333 speed, with the 7-7-7-21-2N @ 1.5V spec?
