*** G.Skill DDR3 Dual & Triple Channel kits - Good Deals to be had ***
Suspended
18 Oct 2002
OcUK HQ
*** *** G.Skill Perfect Storm "Low Latency" 6GB (3x2GB) DDR3 PC3-16000C8 2000MHz Triple Channel Kit (F3-16000CL8T-6GBPS) @ £195.99 inc VAT *** ***
The F3-16000CL8T-6GBPS is a 6GB matched kit of DDR3 SDRAM DIMMs built using G.Skill's latest high performance heat sink. This part delivers outstanding performance in the latest generation of tri-channel DDR3-based motherboards. It has been tested extensively in popular DDR3 motherboards to ensure compatibility and performance at its rated speed.
- Each tripple channel kit is tested together at 2000MHz
- Tested and packaged in tripple channel kits.
- Packaged together immediately following system test
- SPD programmed at: JEDEC standard 8-8-8-21 values at 2000MHz
- 6GB of DDR3 memory
- 1.65V Tested
- Using DHX technology providing maximum cooling
- 100% tested at 2000MHz in high performance DDR3 motherboards
- Lifetime warranty
Only £195.99 inc VAT.
ORDER NOW
*** *** G.Skill Trident "Low Latency" 6GB (3x2GB) DDR3 PC3-12800C6 1600MHz Triple Channel Kit (F3-12800CL6T-6GBTD) @ £137.99 inc VAT *** ***
The FF3-12800CL6T-6GBTD is a 6GB matched kit of DDR3 SDRAM DIMMs built using G.Skill's latest high performance heat sink. This part delivers outstanding performance in the latest generation of tri-channel DDR3-based motherboards. It has been tested extensively in popular DDR3 motherboards to ensure compatibility and performance at its rated speed.
- Each tripple channel kit is tested together at 1600MHz
- SPD programmed at: JEDEC standard 6-7-6-18 values at 1600MHz
- 1.65V Tested
- 100% tested at 1600MHz in high performance DDR3 motherboards
- Lifetime warranty
Only £137.99 inc VAT.
ORDER NOW
*** *** G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-16000C9 2000MHz Dual Channel Kit (F3-16000CL9D-4GBRH) @ £78.99 inc VAT *** ***
The F3-16000CL9D-4GBRH is a 4096MByte matched pair of DDR3 SDRAM DIMMs built using G.Skill's latest high performance heat sink. This part delivers outstanding performance in the latest generation of dual-channel DDR3-based motherboards. It has been tested extensively in popular DDR3 motherboards to ensure compatibility and performance at its rated speed.
- Each module pair is tested together at 2000MHz
- Tested and packaged in pairs
- SPD programmed at: JEDEC standard 9-9-9-27 values at 2000MHz
- 4096 Megabytes of DDR3 memory
- 1.65 Volt Tested
- Lifetime warranty
Only £78.99 inc VAT.
ORDER NOW
*** *** G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit (F3-12800CL7D-4GBRH) @ £73.99 inc VAT *** ***
TThe F3-12800CL7D-4GBRH is a 4096MByte matched pair of DDR3 SDRAM DIMMs built using G.Skill's latest high performance heat sink. This part delivers outstanding performance in the latest generation of dual-channel DDR3-based motherboards. It has been tested extensively in popular DDR3 motherboards to ensure compatibility and performance at its rated speed.
- Each module pair is tested together at 1600MHz
- SPD programmed at: JEDEC standard 7-7-7-24 values at 1600MHz
- 1.65 Volt Tested
- Lifetime warranty
Only £73.99 inc VAT.
ORDER NOW
*** *** G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (F3-12800CL8D-4GBRM) @ £67.99 inc VAT *** ***
The F3-12800CL8D-4GBRM is a 4096MByte matched pair of DDR3 SDRAM DIMMs built using G.Skill's latest high performance heat sink. This part delivers outstanding performance in the latest generation of dual-channel DDR3-based motherboards. It has been tested extensively in popular DDR3 motherboards to ensure compatibility and performance at its rated speed.
- SPD programmed at: JEDEC standard 8-8-8-24 values at 1600MHz
- 1.65 Volt Tested
- Lifetime warranty
Only £67.99 inc VAT.
ORDER NOW
*** *** G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (F3-12800CL9D-4GBRL) @ £66.99 inc VAT *** ***
The F3-12800CL9D-4GBRL is a 4096MByte matched pair of DDR3 SDRAM DIMMs built using G.Skill's latest high performance heat sink. This part delivers outstanding performance in the latest generation of dual-channel DDR3-based motherboards. It has been tested extensively in popular DDR3 motherboards to ensure compatibility and performance at its rated speed.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1600MHz
- 1.65 Volt Tested
- Lifetime warranty
Only £66.99 inc VAT.
ORDER NOW
Christ almighty, they look impressive.
2 questions about the triple channel kit with the fans:
1) anyone tried this or a similar setup, how loud are the fans? Voltage controllable?
2) How do you install it, do you stick the ram in then attach the cooling, or do you have to line it all up and get the RAM in all at once?
Well I can zilch information about these on the intranetz but Gskill are pretty decent manufacturers and these might be good for some AMD rigs since they run at such a low voltage. That should mean more overclocking headroom + lower temps at stock volts right?
