*** G.Skill DDR3 Dual & Triple Channel kits - Good Deals to be had ***
Suspended
18 Oct 2002
OcUK HQ
*** *** G.Skill Perfect Storm "Low Latency" 6GB (3x2GB) DDR3 PC3-16000C8 2000MHz Triple Channel Kit (F3-16000CL8T-6GBPS) @ £195.99 inc VAT *** ***
The F3-16000CL8T-6GBPS is a 6GB matched kit of DDR3 SDRAM DIMMs built using G.Skill's latest high performance heat sink. This part delivers outstanding performance in the latest generation of tri-channel DDR3-based motherboards. It has been tested extensively in popular DDR3 motherboards to ensure compatibility and performance at its rated speed.
- Each tripple channel kit is tested together at 2000MHz
- Tested and packaged in tripple channel kits.
- Packaged together immediately following system test
- SPD programmed at: JEDEC standard 8-8-8-21 values at 2000MHz
- 6GB of DDR3 memory
- 1.65V Tested
- Using DHX technology providing maximum cooling
- 100% tested at 2000MHz in high performance DDR3 motherboards
- Lifetime warranty
Only £195.99 inc VAT.
ORDER NOW
*** *** G.Skill Trident "Low Latency" 6GB (3x2GB) DDR3 PC3-12800C6 1600MHz Triple Channel Kit (F3-12800CL6T-6GBTD) @ £137.99 inc VAT *** ***
The FF3-12800CL6T-6GBTD is a 6GB matched kit of DDR3 SDRAM DIMMs built using G.Skill's latest high performance heat sink. This part delivers outstanding performance in the latest generation of tri-channel DDR3-based motherboards. It has been tested extensively in popular DDR3 motherboards to ensure compatibility and performance at its rated speed.
- Each tripple channel kit is tested together at 1600MHz
- SPD programmed at: JEDEC standard 6-7-6-18 values at 1600MHz
- 1.65V Tested
- 100% tested at 1600MHz in high performance DDR3 motherboards
- Lifetime warranty
Only £137.99 inc VAT.
ORDER NOW
*** *** G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-16000C9 2000MHz Dual Channel Kit (F3-16000CL9D-4GBRH) @ £78.99 inc VAT *** ***
The F3-16000CL9D-4GBRH is a 4096MByte matched pair of DDR3 SDRAM DIMMs built using G.Skill's latest high performance heat sink. This part delivers outstanding performance in the latest generation of dual-channel DDR3-based motherboards. It has been tested extensively in popular DDR3 motherboards to ensure compatibility and performance at its rated speed.
- Each module pair is tested together at 2000MHz
- Tested and packaged in pairs
- SPD programmed at: JEDEC standard 9-9-9-27 values at 2000MHz
- 4096 Megabytes of DDR3 memory
- 1.65 Volt Tested
- Lifetime warranty
Only £78.99 inc VAT.
ORDER NOW
*** *** G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit (F3-12800CL7D-4GBRH) @ £73.99 inc VAT *** ***
TThe F3-12800CL7D-4GBRH is a 4096MByte matched pair of DDR3 SDRAM DIMMs built using G.Skill's latest high performance heat sink. This part delivers outstanding performance in the latest generation of dual-channel DDR3-based motherboards. It has been tested extensively in popular DDR3 motherboards to ensure compatibility and performance at its rated speed.
- Each module pair is tested together at 1600MHz
- SPD programmed at: JEDEC standard 7-7-7-24 values at 1600MHz
- 1.65 Volt Tested
- Lifetime warranty
Only £73.99 inc VAT.
ORDER NOW
*** *** G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (F3-12800CL8D-4GBRM) @ £67.99 inc VAT *** ***
The F3-12800CL8D-4GBRM is a 4096MByte matched pair of DDR3 SDRAM DIMMs built using G.Skill's latest high performance heat sink. This part delivers outstanding performance in the latest generation of dual-channel DDR3-based motherboards. It has been tested extensively in popular DDR3 motherboards to ensure compatibility and performance at its rated speed.
- SPD programmed at: JEDEC standard 8-8-8-24 values at 1600MHz
- 1.65 Volt Tested
- Lifetime warranty
Only £67.99 inc VAT.
ORDER NOW
*** *** G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (F3-12800CL9D-4GBRL) @ £66.99 inc VAT *** ***
The F3-12800CL9D-4GBRL is a 4096MByte matched pair of DDR3 SDRAM DIMMs built using G.Skill's latest high performance heat sink. This part delivers outstanding performance in the latest generation of dual-channel DDR3-based motherboards. It has been tested extensively in popular DDR3 motherboards to ensure compatibility and performance at its rated speed.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1600MHz
- 1.65 Volt Tested
- Lifetime warranty
Only £66.99 inc VAT.
ORDER NOW
