Well today i received my Second! set of faulty HZ sticks. Errors in memtest within 5 mins. I suppose they were better than my last set they failed within a minute.Bare in mind this is at stock.
Will send a web note off soon.
I dont know if i can really ask this but am i stuck with HZ now or can i spend a little more around £80 and get some of these.
OCZ 2GB (2 x 1GB) PC4000 Dual Channel Platinum Series EB-DDR CAS3 (OCZ5002048EBPE-K) (MY-058-OC)
I now do not trust G.skill and would not like to spend money on their products.As they could start failing X no. of months down the line. I know this could happen with any manufacturers product.But i have not had any problems with my 2GB Geil Value which were running and soon will be again after this post @2.5-3-3-6 at 240HTT
Justin
Justin
Im going to send a webnote or get a direct RMA, the reason i chose GSkill in the 1st place was because i thought they would work 1st time.
Its Infineon BE-5, currently running at 220 @ 2-3-2-5 and it doesn't seem to dislike high voltages, I've tried it at 3v with no probs. I realise this isn't the best choice of RAM if you require 250MHz but with Athlon64's it seems to be about CPU speed so running a 333 divider seems to be the sweet spot.
