G.Skill PC2-8500C5 (2x2GB) or OCZ (2x2GB) PC2-8500C5 1066MHz Reaper HPC ?
31 Mar 2008
What should I get get for my new Q6600 overclocking system?
OCZ 4GB (2x2GB) PC2-8500C5 1066MHz Reaper HPC Edition Dual Channel DDR2 (OCZ2RPR10664GK) http://www.overclockers.co.uk/showproduct.php?prodid=MY-110-OC&groupid=701&catid=8&subcat=817
or
G.Skill 4GB DDR2 PK PC2-8500C5 (2x2GB) CAS5 Dual Channel Kit (F2-8500CL5D-4GBPK) http://www.overclockers.co.uk/showproduct.php?prodid=MY-023-GS&groupid=701&catid=8&subcat=817
The G.Skill has slightly better timing but i've also seen this:
G.Skill 4GB DDR2 PQ PC2-8000C5 (2x2GB) CAS5 Dual Channel Kit (F2-8000CL5D-4GBPQ) http://www.overclockers.co.uk/showproduct.php?prodid=MY-022-GS&groupid=701&catid=8&subcat=817
These ones are £20 cheaper but will they still be good for overclocking the Q6600 system. Prob gonna get a Abit IP35 Pro motherboard
I am pretty sure those all use the same Powerchip ICs...so they should overclock rougly the same.
Those will do me nicely thankyou verymuch am not lookin to run 4 gig @ 1066 anyway as i dont think its possible on my set up am struggling to run my ballistics at higher speeds at the mo,am not buying just yet even tho ive upgraded to vista64 with only 2gig it will do for now until i get some more Mula
