- 14 Oct 2007
- newcastle
I currently have G.skill Trident Z 3200 CL14 what timings would I need to run to bump it up to 3800mhz so I can run a higher infinity fabric
I’m on Ryzen 5900x now mate just haven’t updated my sigI would first try them at 3600 / 1800 IF / CL16. If stable then try for 3800 / 1900 IF / CL14
Use Thaiphoon to read memory
Click Report, scroll down and click 'show delays in nanoseconds'
Then export complete HTML report
Use a tool like Ryzen DRAM calculator to read the report (not sure what Intels alternative is)
Select Calculate Safe / Calculate Fast to show timings and voltages required for safe/fast presets
Good stuff, in that case go for it with Thaiphoon and Ryzen DRAM calcI’m on Ryzen 5900x now mate just haven’t updated my sig
These are my sticksGood stuff, in that case go for it with Thaiphoon and Ryzen DRAM calc
FYI
DRAM calc I imported my XMP timings for Teagroup 8 pack 3600Mhz CAS 16 memory.
Selecting fast present for 3800Mhz shows CAS 16 timings, max 1.45V.
It's running happily at 3800Mhz CAS 14, 1.5V.
Depends on the memory kit you have but worth first trying the fast present timings for 3600Mhz
Spot on mate, thank you
Some tips for 3800
