g skill trident z lighting control
13 Jan 2006
Wigan
Hi
anyone having issues with the G skill lighting control? it just doesnt load my settings on start up. i have to apply it every boot up.
anyone got a fix for this?
cant see any options really in the app at all.
thanks.
What motherboard are you using etc.?
MSI Mag X570 Tomahawk
5900X
3080 FE
GSkill TridentZ RGB 32gb 3600
The odd time it will load my custom colours but most of the time i have to open the app and press apply. it has my colours set, just doesnt enable. annoying..
I had a similar issue with my Gigabyte Motherboard - Only way to fix this was to use the GSkill RGB Utility which on start-up used to fix the RGB properly!
I have 5900x MSI 570x Unify and GSkill TridentZ RGB 32gb 3600 I use MSI Center to set all the systems RGB including the RAM even with MSI Center not set to start when system start it still keeps the custom set rgb
