Hi, I'm in the process of a new system build primarily for gaming but also for some coding/development work for my son. I have already purchased a Gigabyte Aorus Master X570 motherboard and Ryzen 7 3700X cpu.
Mild overclocking will probably be implemented once built. Just wondering if anyone with the same motherboard/cpu combination as this has fitted the G. Skill F4-3600C16Q-32GTZNC. And if so is stability at XMP settings achievable and stable. This is the 4 x 8gb set with 16-19-19-39 timings. I think it's Hynix not Samsung B-Die. Price is a factor in considering this set, as the B-Die 16-18-18-36 set is over £350. 4 sticks with RGB is preferred purely for looks, as I realise 2 x 16gb sticks will probably be more reliable to fit. Thanks.
