G static - network access denied
19 Nov 2024
Kent
Hi, any Android users started to experience glitches connecting to 4g and 5g networks here in the UK?
I've been using Talk mobile (Vodafone is the carrier) for about a year now without problems.
Recently I've started to get the android prompt that I might have limited access to the network because I may have exceeded my data limit. This is not the case however because my monthly limit is 50gGb and I'm only a light business user
If I click on the prompt it takes me to a (I assume) gateway portal - white page with the heading G Static and the toggle options are either "Trust this network" or continue.
I'm loathed to interact with this because it seems suspicious to me. Re- starting the phone will cure it. It's only happening when I switch from home Wifi to the phone network in the morning for work. As I stream Apple music or BBC sounds through Bluetooth in the car having to restart isn't always feasible.
Can anyone shed light on what this G Static portal is please?
Are you using androidauto? g static is just a site owned by google, you can whitelist it quite safely - connectivitycheck.gstatic.com
