- 30 Oct 2002
- Inverness (UK)
So on my old PC, ran a 2nd monitor enabled 99% of the time.
New PC:
Asus Hero VIII
i7 6700K
GTX 980Ti
Asus XB270HU (G-Sync)
Other non-G-Sync monitor and standard TV
With Main monitor via DP Cable
Other Monitor with DP -> HDMI Cable
Or TV with HDMI cable (From HDMI Port)
G-Sync Enabled
With either monitor OR TV enabled, the FPS in games is 2~20 FPS.
Only single monitor used, 60~250 FPS.
Repeatable, all games and Firestrike etc
Have set nVida CP to Single Display Performance mode, uninstalled GE Force Experience, Disabled Transparency.
Nothing seems to make a difference.
Disable G-Sync = All works perfectly.
Is there anything I can do to get G-Sync enabled on main display, with a 2nd monitor (non-G-Sync) enabled?
New PC:
Asus Hero VIII
i7 6700K
GTX 980Ti
G-Sync Enabled
