G-Sync Info
20 Jul 2012
Manchester
Hi, I've never used a G-Sync monitor and I'm just wondering what happens when you're capped at the refresh rate with a G-Sync panel.
Is V-sync enabled and therefore you get input lag? Or is it like Fast Sync where you get no tearing and no input lag?
Cheers :)
Cheers :)
Vsync gets enabled. You then get smeary mouse i.e. inputlag.
Turn off Vsync in Nvidias Controlpanel - Manage 3D Settings - Global.
Cap fps or let them flow, be wary of possible tearing past your Hertz cap.
Oh :(
So it's better to just use Fast Sync if you can keep a constant 60fps?
