G-SYNC not sure it's working (or it's just me)
31 Dec 2017
Good Evening all,
I have a Acer Predator 165hz IPS G-SYNC monitor
When i play games at 100 plus frames the games feel like butter, but as soon as it hit's 90-80 fps it starts to feel sluggish kind of like a slow down!!
Is this just me or do other people have this issue?
Regards
Use the indicator in the gpu settings is it showing it is on?
GSync will not work miracles all the time some games still need over 120 plus frames i found others still felt bad i disliked Dota and The Blizz one but then others work great. Overwatch is the best example 120 is ok on 240hz but ideally 180 feels immense.
So yea it does that at 90fps get your computer up to 120.
Agree completely, 90fps is still 90fps lol.
I had a go of a 240hz panel and loved it, then went back to my 144hz and it felt sluggish ;0.
Its not workable to go back im waiting on The NXG251 but i will not use it below half fps as a rule or it gets nasty. As you say 90fps is still 90fps.
Good Evening all,
Regards
have you got vsync off in the games?
