Morning all,
TL;DR
What are your G-Sync/V-Sync options set to?
Longer version
After recently purchasing a Dell S2716DG G-Sync monitor I wondered how to tell whether G-Sync is actually working, and what V-Sync options I should use.
In the Nvidia Control Centre (NVCP) I have enabled G-Sync and the monitor menu mentions G-Sync at the bottom when I click the buttons, however I get no indication when playing that G-Sync is on, is there such an indication (other then game play)?
Also, do I enable V-Sync alongside G-Sync and do I enable it in the NVCP and in-game, or in one but not the other. Views on the web seem mixed, I'd like to know what you do.
I mention all this as because in Metro LL Redux I was hitting +200FPS with Nvidia recommended settings and the graphics were not great. I then capped the FPS with RTSS at 130 and it was much better but I wouldn't say buttery smooth. V-Sync didn't seem to limit the frames, hence using RTSS, anything I should check to limit in future without using RTSS?
Thanks for reading.
Anthony
I've pulled my questions out for easy answering:
What are your G-Sync/V-Sync options set to? (In-game & NVCP)
Is there such an indication to show G-Sync is operational (other then game play)?
Anything I can do to limit in future to limit FPS without using RTSS?
TL;DR
Longer version
Thanks for reading.
Anthony
