G1 Guerrilla Ethernet and Sound driver issues Windows 10
12 May 2010
Walsall
Hi guys,
I was wondering if anyone is able to help at all as I'm a bit stuck at the moment!
I'm running Windows 10 pro on my old x58 system and having all sorts of issues trying to get Windows to recognise my ethernet and sound cards. Aside from this everything else seems to run perfectly so I'm well miffed that I'm so close to running Windows 10, yet so far at the same time!
The only audio adapter showing in Windows is for my R9 290x, windows is detecting absolutely zip as far as ethernet and audio is concerned. Picked up my pcie wireless adapter fine which was annoying.
Any help as far as drivers or workarounds to get things up and running would be most appreciated!
System is as follows:
Gigabyte G1 guerrilla
Xeon 5650
Radeon R9 290x
Hyperx fury 16gb
Intel SSD
Thanks! :)
Thanks dLockers, but I already downloaded the realtek driver you linked me to. Windows is telling me that there is no audio device installed and the same goes for the Bigfoot ethernet card. For some reason Windows doesn't think they exist! Any ideas?
