G11 Problems
5 Mar 2010
I've had a G11 for a year now and never had any problems, I packed up my pc to take home for Christmas and when setting it up at home as soon as i plug the keyboard in I get a BSOD.
I know the keyboards not faulty as it works fine on several other machines. I've emailed Logitech for support and the best solution they can come up with is a re-installation of the o/s. Which I really don't want to have to do unless there are no other solutions.
Is there a way I can manually remove the drivers and let windows install the necessary drivers when I plug it back in. A friend told me that the keyboard drivers is usually under the "Human Interface Devices" section in device manager. But looking at that I have about 15 drivers installed for different things.
Any help appreciated,
strange, yeah you can try updating the firmware on the G11 using another computer and uninstalling all the drivers on your computer, then start from fresh, see if that helps
