G15 & iTunes
Man of Honour
20 Sep 2006
Using Windows 7, iTunes 9.
I can no longer control iTunes with my Keyboard which is quite irritating. I have had a Google and the only suggestions are to reinstall iTunes which I really don't want to do.
Any ideas?
Why don't you want to reinstall itunes? If you make a backup of your itunes folder (the one that has xml and .itl file for library) you won't lose playcounts or anything.
Try reinstall the gamepanel manager.
the thing i found happen with mine is when game panel some how sets the control buttons to media player :S
I reinstalled game panel to the newest version and it solved it.
I had the exact same problem. However, I found a .dll file online which you put into the itunes directory which lets you control itunes even when it isn't the active window!
So for example, if you had a full screen game open you can still skip/pause etc your music.
If you're interested I can email you the file (I can't find the site I got it from).
