G15 keyboard, Macros not working in TF2
8 Feb 2008
Edinburgh
I'm trying to set a simple macro up for TF2, for disguising as the Spy. However, the macros aren't working in TF2 on the Logitech G-15 keyboard. Does anyone use this keyboard and can get the macros to work?
I've got everything set up as it should be (as far as I can see) and I've tested the profile and the G keys work perfectly out of TF2. I'm trying to set a G-Key to a certain disguise. So, for G3...I set it to press 4, release 4, press 3, release 3. That should disguise as a Pyro but in TF2 I get zero response from it. G1 is set as F1 by default and that opens up the Steam Community for me, so the G keys are working in TF2....just not the macro thingys.
If anyone has this keyboard or some experience in this then could you help me out? :confused:
just press 4>3 ?
once you've done that, you only have to press 'B' to use the last disguise.. the same number of key presses as the macro ;)
Yeah it's just I wanted to try out making a macro as I have yet to find a use for the G-Keys in any of my games :P
