G15 not working in BIOS
Caporegime
13 Jan 2010
Llaneirwg
hi
i know it should work but it doesnt, and i cant seem to find why, legacy is enabled in bios, other usb keyboards work [even my bluetooth keyboard works in bios] so why doesnt this?
anyone come across a fix?
If it is a asus board then there was a bios bug which means they are not detected, chekc the asus website if you need a bios update, specifically my p6t deluxe v2 needed such an update
ok looks like this, its plugged into the motherboard, i have the p6t se, looks like a bios update is in order then :/
Sounds a bit odd, im using a g15 and a p6t dlx v2 without issues, the board is still on the bios revision that it shipped with.
