just bought a g15 v1 off my mate and was thrilled
but it was a tad dirty so decided to give it a clean.....
upon removing the black trim and trying to carefully remove the ribbon cable it snapped clean in half
would have been nice if the ribbon had a cm or 2 more slack as i'm sure it would have been fine then
any ideas how to get a replacement/fix? will logitech send me a new ribbon cable? or does anyone have a broken one they wouldn't mind sending me the cable
or is there a way to fix it? there are lots of connectors so trying to solder on wires would be a pain in the ***
can i get the same ribbon cable form somewhere else?
help meeeeeee
help meeeeeee
