Hi everyone, I have a relatively new ASUS G16 and have had this issue since the start, I’m not too concerned about it but just wanted to definitely check it’s coil whine?
The issue only occurs when the G16 is on battery mode, as soon as I plug in the AC adapter the issue goes away.
It sounds quite loud on the audio recording, but you can’t heard it unless you’re in a silent room.
Is this coil whine which doesn’t affect the functionality of the device?
Many thanks
https://vocaroo.com/18KYTpSu63x3
Many thanks
