Hi all has anyone been using or trying to use logitech g19 keyboard?.
just sent mine back and shop yoyo! want to send off to check it out and want £15 if they can't find a problem?.Been onto logitech few times about problems theirs also 40 pages about it on there forum from users. Has when you boot up menus don't function ie lights don't work or screen don't display item's or it just crashes out and then have to unplug power lead to keyboard! also when usb drops out but won't reconnect till you unplug power lead!
Also laggs out game play amongst other things?.
Just had my pc reformatted to try to clear it out as thought problem with pc but it seams that it's keyboard rewriting registry as mentioned in forums by a guy that downloaded a key watch programme that found it set up something in the registry ie toggle command?
If anyones having problems or want to find out more thread's called key buffer over run
