g27 dirt 3 help
24 Mar 2007
hello all,need a bit of help with those with a g27.I cant seem to setup my wheel right when playing dirt 3.Can anybody give me a guide to which settings to use.I keep messing around with them but cant find a good setup.I have been using the ingame settings and the profiler.The car just does not feel responsive enough and i keep crashing.
If the wheel is unresponsive then perhaps the wheel lock is set too high?
How many degrees of rotation are you using? I would say use 540 degrees
I use around 360 on dirt3 with my G25 set on the logitech profiler. I would start from 260 & move your way up till you find what you are happy with personally.
