G29 pedal upgrade
9 Aug 2013
S. Wales
I'm looking to upgrade the pedals on g29 as I really don't get on with them. Noticed moza srp are only around £150, fantec ones seem lot more with load cell added. Simagic p500 just released.
Any other ideas around the budget or are the srp the best option
Thrustmaster T-LCM or look up Simjack pdeals which seem to get decent write ups on Reddit.
I've never used Moza and the Simagics are new so no idea about them.
I am sure there was a mod you could apply to G29 pedals to make them better, have you looked into that mate.
There are loadcell mods. But pointless as you can pick up simsonn or simjack pedals for under £200.
And the make massive difference. My times improved hugely
I've not heard of those brands Simsonn or Simjack. Are they new? Any reviews? @MCFC_ANDY
I have g29 also and would like to upgrade it. But no point getting similar budget level replacement, have to go load cell.
Not sure whether to get fanatec or moza bundle with wheel and pedals or separate pedals like the brands you just mentioned.
this should help
link
decent LC pedals are the biggest gain, my g29 pedals are not gathering dust, DD wheels just make you smoother tbf, ive tried both and stay with my G29 wheel, i cant justify the upgrade cost atm, i may in time though
