Deleted member 329
Deleted member 329
G4 MDD Upgrade Advice
Hello,
I recently got a MDD G4 second hand with the intention of creating a home server that in theory should kick ass when compared to what you I could do with the same money.
I was thining about getting a time capsule but in the end decided that for the same money i should really be able to do what time capsule does and more.
I now have the G4 arrived today
So ive installed leopard client atm although i am thinking of getting the server edition down the line if its needed.
I have a few issues with it that i am hoping to solve .
#1 I can seem to get 1650 x 1080 resolution to work - My monitor is a 22" Acer with VGA connection and i am connected via DVI - VGA adapter.
My monitor resolution is not listed at all
I have a the Radeon 9000 Pro in the system which should really beable to output that res.
Listed are much higher resolutions which are supported.
So far i have tried a third party programme to enable the res ( cant remember what it was called, but i found it during my initial search for answers )
This actually crashed my mac and i had to reinstall leopard.
So i am thinking maybe its somthing to do with the ROM version on the card?
I am really struggling to find ANY information regarding the latest ATI 9000 Pro ROMS on apples site or ATI's site.
So its a bit of a problem.
#2 I need to get USB 2.0 in this machine so i can connect external hard drives and other USB 2.0 gear to it.
I really want to make sure i get the right one as i hear that some chipsets via?? might be problematic with the G4
#3 I would like to get SATA II into this machine so i can add some SATA and SATA II hard drives to it.
Any advise you could offer would be very helpful
thanks
Hello,
thanks
