G400 Freezing?
21 Jan 2010
Ceredigion
Hey guys,
Got a G400 that keeps freezing both in desktop and in applications. Running the latest drivers (LGS 8.35.18)
It freezes for anywhere between 2 and 5 seconds, and there is no disconnect sound, infact the optics remain on.
I've tried different usb ports, unistalling the drivers, reinstalling the drivers, backdating drivers and now I've run out things I can think of to test.
Any ideas?
Cheers
2x G400s in 8 months now.
Dont think I'll be getting another. Any recommendations for a mouse of a similar price range?
Get it replaced, Logitech support is good.
Or are you thinking about getting it replaced then selling it immediately?
Mine is over a year old and it's fine. You're either very unlucky or something else is causing this problem.
The first rma was due to a design fault, they revised that quite quickly - seemed to be quite a common issue on the Logitech support forums and according to a quick google.
This issue does really confuse me though, gotta be honest.
There are 2 ways,
1) Get in touch with logitech and get a replacement, because it shouldnt be really doing this
2)
