A laser mouse does not have any visible light and my G5 certainly never showed any light. You are thinking about optical mouse that shows a red light to track movement.
As i said before, the sensitivity switched from its normal setting to incredibly low completely at random when playing a game.
I hadn't caught any of the dpi buttons as even when i pressed them they made no difference to it's responsiveness.
Can the people who believe the laser isn't visible please pick your g5 off the desk and gently rotate it while looking down the sensor hole? That isn't a backlight for the weights, its a piercing red colour which can only be the laser.
Yep, same on my G500, it is extremely faint though.I have a g5 and you can see the laser but you really have to look hard for it.
even when i put the mouse bottom near the palm of my hand, in darkness, theres nothing
