g510 Vs G15
7 Feb 2011
Stoke on Toast
i need a new keyboard my lycosa in all it's prettiness has decided to get sticky keys far too often for my liking and unplugging plugging in the usb is annoying me now.
So i want a g15 everyone says they are great but they are EOL.
So the question simply is, which is better?
the new g510 or should i buy a g15 from somewhere still selling them.
Any budget? I have the G19 and G9x and never looked back : ) The G19 is beast, the G9x I believe is a love it or hate it affair. I was a big G5 user and so the G9x was the natueral choice for me.
IF you are on a budget, go with G15, LCD display will quickly become a "how did I live with out this" affair. ESPECIALLY if you play WOW!
not a wow feind more of a source/hon/lol junky, magicka is awesome too.
g19 is a bit too much for a keyboard 100 is sorta the max though i'm looking to keep it as close to 80 as poss, this Lycosa i picked up for 21 cus it's US layout it's done me proud and i do love it but the sticking keys annoy me. and after heavy use the keys are a tad transparent :/
the reason i ask is becuase the g15 is EOL and unavail from many places with decent prices and returns policies. not a fan of Ebay buying, So essentially has anyone used the g510 is it better or worse or the same as the g15
G510 is just the new g15 so it will be basically the same, as is the g19. It doesnt matter about decent return policy since Logitechs service is second to none, and if it fails in warranty youll get a shiny new better keyboard, and out of warranty and you will get a 50% off voucher from anything on their site.
If you can afford it, the g510 will be better, I wouldnt have said its worth the extra price tag (got my g15 rev 2 for 55 ages ago) but just noticed G15's cost like £80 now anyways.
LCD screen is overrated though, it can be useful for having it display vent/system info, but if you dual monitor (but only game on one) or something then its not really "needed", just a bit of extra shiny.
