G513 carbon, 0 not working on num pad?
1 Dec 2010
Middlesbrough
Ok so i just got the G513 carbon with the linear switches for my birthday, all the numbers on the key pad over on the right work great apart from the 0 key .... I just cant get this key to type the number 0! ... I know the key works because i use that button to record clips withing shadow play, even now if i unbind the key and rebind it they key registers that i just pressed the Num0 key and it records in game footage when i press it just fine.
Also withing LGS if i click the "Customise G-keys" then on the left click on of the commands, click "edit" then "keystroke" i can click the 0 button on the keypad and its actually registers as "NUM 0" i just cant work out how to get it to type the number 0 in a web search engine or a text document for example.
I thought the 0 key may be faulty on the key pad but i swapped over to a old Logitech G15 i had in the loft and the 0 does not work on that on the keypad either but just like the G513 all other numbers work fine .... Im really thinking its a setting within windows 10 or LGS that i cant seem to find!
I think you should try disabling/uninstalling Shadow Play to see if that makes difference.
Looks like it has "stolen" that key from normal programs or messes Windows somehow.
Yes i after messing around for a couple of hours on Tuesday evening i realised it was because i had the Num0 bound to shadowplay, i un-bound this and the key works fine now lol. Really baffled me for hours, almost sent it back for a replacement too.
