G550W speakers
31 Mar 2006
have just got a creative G550W speaker system, my problem is that it came with a European 2 pin power cable as you know we use a 3 pin plug but on the back of the amp where the power plugs in it says 230v and we use 240v will they work with our 240v power I have put a 3 pin plug on the power cable but as I'm not sure off the volts I have yet to plug them in wanted some advice first.
So the o
Thanks
Dean
Thanks, I just wanted to make sure. So what I have done is put 3 pin plug on the ends of the power cable there is only l & N no earth. I will set it up to moz and I am looking forward to it as I have read some good reviews about these speakers and they sound grate.
cheers
Dean
