Hi All,
I have Logitech G613 and I must say it's an amazing keyboard. Apart from the fact that about 2 months ago it developed key chattering. It's the thing that causes single key press to type in same key twice. Happens quite often and I must say it's becoming more and more annoying.
I've removed all keys, cleaned it from the outside.
I've changed batteries.
I have no idea what else to try...my next idea is to open it up and clean it from the inside but I'm not sure if it's worth it as it's a mechanical keyboard and it won't have the same kind of membrane layer as normal keyboards have so not sure if I should even attempt doing so.
Any ideas? Does anybody own this keyboard? Do you have same issue and have managed to fix it?
Thanks,
Arturs.
Thanks,
Arturs.
