Wooops, Make sure when you plug the power pack in, you plug it in the correct way round. Just been laying on the bed with the laptop, slipped the power lead in while not paying attention, (Had it at a a 90 degree angle than it should have been at) and heard "bzzzzz" and a nice smell of electrical burning.
I had a look at the pins on the powerlead, one of the +(plus) one is black inside and managed to bend the pin a little bit inside due to the electric being on etc etc. I've managed to bend the pin back out and get it plugged in, seems to be working SO far, but from my knowledge of experiance, a burnt pin wouldn't be conductive, not sure if it is or not now, so only time will tell. Not the bestest plug in the world
! - Really suprised I haven't fried the power board inside! :|
So, My question is, Where can I find a replacement pack just incase? And does anybody have any helpful information on this subject? Gonna need a new one as due to the pin inside being bent, it's making the plug a bit more stiffer to plug in.
! - Really suprised I haven't fried the power board inside! :|So, My question is, Where can I find a replacement pack just incase? And does anybody have any helpful information on this subject? Gonna need a new one as due to the pin inside being bent, it's making the plug a bit more stiffer to plug in.
