GA-965P-DS3 S775 I965P ATX
7 Feb 2004
Whats this like?
Product Type Main board
Form Factor ATX
Width 30.5 cm
Depth 21 cm
Compatible Processors Pentium 4, Pentium 4 Extreme Edition, Celeron D, Pentium Extreme Edition, Pentium D, Core 2 Duo, Core 2 Extreme
64-bit Processors Compatibility Built-in
Processor Socket LGA775 Socket
Multi-Core Support Dual-Core
Chipset Type Intel P965 Express / Intel ICH8
Max Bus Speed 1066 MHz
BIOS Type Award
Storage Controller ATA-100, ATA-133, Serial ATA-300 (RAID)
Power Connectors 4-pin ATX12V connector, 24-pin main power connector
Memory
Supported RAM Technology DDR II SDRAM
RAM Installed ( Max ) 0 MB / 8 GB (max)
Supported RAM Speed PC2-4300, PC2-6400, PC2-5300
RAM Features Unbuffered, two DDR channels
Expansion / Connectivity
Expansion Slots Total (Free) 1 processor - LGA775 Socket
4 memory ( 1.8 V ) - DIMM 240-pin
1 PCI Express x16
3 PCI
3 PCI Express x1
Storage Interfaces Intel ICH8 : ATA-100 - connector(s): 1 x 40pin IDC - 2 Device(s)
Intel ICH8 : Serial ATA-300 - connector(s): 4 x 7pin Serial ATA - 4 Device(s)
ATA-133 - connector(s): 1 x 40pin IDC - 2 Device(s)
Serial ATA-300 - connector(s): 2 x 7pin Serial ATA - 2 Device(s) - RAID 0 / RAID 1 / RAID 0+1 / JBOD
RAID Features Intel Matrix RAID Technology
Interfaces 1 x storage - floppy interface - 34 PIN IDC
1 x audio - line-In - 4 PIN MPC
1 x mouse - generic - 6 pin mini-DIN (PS/2 style)
1 x keyboard - generic - 6 pin mini-DIN (PS/2 style)
1 x audio - SPDIF output - TOS Link
1 x audio - SPDIF output - RCA
1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25)
4 x Hi-Speed USB - 4 PIN USB Type A
1 x serial - RS-232 - 9 pin D-Sub (DB-9)
1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x audio - line-out (centre/subwoofer) - mini-phone 3.5mm
1 x audio - line-out (rear) - mini-phone stereo 3.5 mm
1 x audio - line-out (side surround) - mini-phone stereo 3.5 mm
1 x audio - line-In - mini-phone stereo 3.5 mm
1 x audio - line-out - mini-phone stereo 3.5 mm
1 x microphone - input - mini-phone 3.5mm
Additional Connectors (Optional) 6 x Hi-Speed USB
Processor
Installed Qty (Max Supported) 0 ( 1 )
Audio
Audio Output Sound card
Signal Processor Intel HD Audio
Audio Codec Realtek ALC883
Sound Output Mode 7.1 channel surround
Telecom / Networking
Networking Network adapter - Marvell Yukon 88E8053 - Ethernet, Fast Ethernet, Gigabit Ethernet
THanks
The P965 DS3 is a very good board. Solid and overclocks very well.
Tho you may want to look at one of the newer P35 DS3 range.
Their specs are listed on the Gigabyte website.
Things like Crossfire, Firewire, and better VRM are usually the only differences.
