- 25 Apr 2011
- Crawley/Gatwick
Morning!
I've got a burning question on my mind, finally decided to go with cheaper x4 quad before dozer arrives, can't take it much more on the laptop.
As far as i can see there are no massive changes in the build of the mobos, caps, sinks seem to be equally good. Colour i dont mind, eSata i don't really use either, GFX wise i only need single card, still going with 6950 2gb, gonna be using xonar dg which will be alright with either one. Both boards are same size, basically extra on FXA is marvell for eSata.
Not sure if i missed anything else, but that seems to be it. Did anyone else have simmilar decision to make, and what they gone with and why. One is around 90 cheapest, the other 120 cheapest, 30 quid difference for minor details.
Any input would be highly apreciated, thanks
