GA-EP45-DS3P - Unstable - Crashes in BIOS!
I'm putting together two machines for the office. Both are meant to be fairly beefy development machines.
The specs are...
I haven't even got as far as putting Vista on yet. This is just memtest86+.
I'm not really used to Gigabyte boards so this M.I.T is a little alien to me (I'm a Abit user, I miss them...).
Here are the settings I'm using (with help from OCZ Forum members...)
The second machine, using the same hardware is in a worse state (I didn't build it! A workmate did, honest!). It wont even get as far as the BIOS.
When you start the machine it powers is up then it powers down for a few seconds then powers up again. It then displays the ugly Fullscreen Logo page but resets before you get to do anything. I've tried different sticks of RAM and even different GFX Cards. Still the same. I've even cleared CMOS and removed the CMOS battery, just to make sure. Still the same.
Any ideas?
The specs are...
- Module size and kit size:-4 x 2gb (8gb) (OCZ2P10664GK)
- CPU model and rated speed:-Intel Q8300 2.5ghz
- Motherboard:-GA-EP45-DS3P
- Video card:-GeForce 9600 GT 1024MB
- Power supply:-OCZ StealthXStream 700w
- Operating System:-Vista 64
- Storage:-2 x 750gb Samsung F1
Code:
Robust Graphics Booster ...................: Auto
CPU Clock Ratio ...........................: 7 X
Fine CPU Clock Ratio.......................: +0.5
CPU Frequency .............................: 2.50Ghz (333x7.5)
** Standard Clock Control
CPU Host Clock Control.....................: [Disabled]
CPU Host Frequency (Mhz) ..................: 333
PCI Express Frequency (Mhz) ...............: [Auto]
C.I.A.2 ...................................: [Disabled]
** Advanced Clock Control..................: [Press Enter]
CPU Clock Drive............................: Default (700mV)
PCI Express Clock Drive....................: Default (700mV)
CPU Clock Skew (ps)........................: 0ps
MCH Clock Skew (ps)........................: 0ps
** DRAM Performance Control
Performance Enhance........................: Standard
Extreme Memory Profile (X.M.P.)............: Disabled
(G)MCH Frequency Latch.....................: [Auto]
System Memory Multiplier .....(SPD)........: [Auto]
Memory Frequency (Mhz) ....................: 1066
DRAM Timing Selectable .......(SPD)........: Manual
** Standard Timing Control
CAS Latency Time...........................: 5
tRCD ......................................: 6
tRP........................................: 6
tRAS.......................................: 24
** Advanced Timing Control.................: [Press Enter] (All on Auto)
tRRD.......................................: 4
tWTR.......................................: 4
tWR........................................: 8
tRFC.......................................: 72
tRTP.......................................: 4
Command Rate (CMD) ........................: 2
** Channel A Timing Settings...............: [Press Enter] (All Auto)
Static tRead Value.........................: 8
tRD Phase0 Adjustment......................: Auto
tRD Phase1 Adjustment......................: Auto
tRD Phase2 Adjustment .....................: Auto
tRD Phase3 Adjustment......................: Auto
Trd2rd(Different Rank).....................: 8
Twr2wr(Different Rank).....................: 8
Twr2rd(Different Rank).....................: 7
Trd2wr(Same/Diff Rank).....................: 9
Dimm1 Clock Skew Control (ps)..............: Auto
Dimm2 Clock Skew Control (ps)..............: Auto
DDR Write Training.........................: Auto
** Channel A Driving Settings..............: [Press Enter]
Driving Strength Profile...................: Auto
Data Driving Pull-Up Level.................: Auto
Cmd Driving Pull-Up level..................: Auto
Ctrl Driving Pull-Up Level.................: Auto
Clk Driving Pull-Up Level..................: Auto
Data Driving Pull-Down Level...............: Auto
Cmd Driving Pull-Down level................: Auto
Ctrl Driving Pull-Down Level...............: Auto
Clk Driving Pull-Down Level................: Auto
** Channel B Timing Settings...............: [Press Enter] (All Auto)
** Channel B Driving Settings..............: [Press Enter]
********* Motherboard Voltage Control *********
Voltage Types...........Normal..........Current
** CPU
CPU Vcore................1.25000v..........: [Auto]
CPU Termination..........1.200v............: [Auto]
CPU PLL..................1.500v............: [Auto]
CPU Reference............0.760v............: [Auto]
CPU Reference2..........0.800v.............: [Auto]
** MCH/ICH
MCH Core.................1.100v............: 1.200v
MCH Reference............0.760v............: [Auto]
MCH/DRAM Ref.............0.900v............: [Auto]
ICH I/O..................1.500v............: [Auto]
ICH Core.................1.100v............: [Auto]
** DRAM
DRAM Voltage.............1.800v............: 1.960v
DRAM Termination.........0.900v............: [Auto]
Channel A Reference......0.900v............: [Auto]
Channel B Reference......0.900v............: [Auto]
Any ideas?
