GA P35 DS4 Memory Voltage Question
29 Sep 2004
Wilt of the Shire
I'm currently running a Q6600 on the P35 DS4 with 4Gb GSkill 6400 RAM. On my old 965 DS4 I had to have the memory voltage raised to achieve overclocks. Does the same thing need to be done with this board?
By default all Gigabyte boards (well it seems the case from the few I've worked on) supply 1.8v to the memory so you'll want to give your RAM a +0.3v boost.
