Hi
Could someone please list the voltages from a program such as speedfan as my motherboard is listing weird values. Both the BIOS and Easy Tune say the +12V line is OK but most other tools list it as a very low value (will add more info later as currently at work).
Could this be caused my some software not fully supporting the IT8718F chip or have gigabyte wired it up in a non-standard way?
Cheers
Cheers
You should try checking the voltages in the BIOS when you get home, it will be more accurate than software monitors.
Connect the green wire to ground (any black wire) to turn it on, and disconnect them to turn it off.
