Ga-p55-ud5 has no sound in XP
22 Sep 2008
Stoke
XP sp3.
I've been trying to get my sound to work all night but nothing works.
The manual tells me if there is a problem to remove the the Microsoft UAA Driver for HD and then install the ones of the motherboard disc but they're not there to start with so I can't unistal them.
When I install the motherboard sound drivers they install without a hitch but there is no sound and no HD drivers showing in system manager, there are a few legacy and codecs listed in sound.
I've tried downloading a few different things but nothing helps
I don't really want win7 or Vista.
Oh when I did first try to install the motherboard driver selecting all there was an error that flashed up very quickly, I don't remember exactly what it said but it was something to do with key count fail it then went into some sort of loading loop for around 5mins so I quit it and restarted and the rest of the installation went perfectly.
Any help on this one please.
Thanks, I will try them next time I try my new PC.
I think I've Identified the problem though, I was using I streamlined version and it appears it doesn't contain some files that are needed for HDAudio.
I've checked my full version of XP and these files are on the disc so a full re-install of XP should fix that problem.
