GA-P55-USB3 Setting up now missing driver disk :(
27 Jul 2006
Huddersfield
Hi there,
I have refit a psu into my old machine to pass onto my friend. Everything has gone fine, PSU works mobo didnt blow up and win 7 installed.
Went to install the drivers and i cant find the drivers disk in the mobo box :(
Ive looked on Gigabytes site for a copy of the Xpress Install that is on there disk but cant find that i have however found all the individual drivers.
Can anyone point me at where i could find Xpress Install all tell me what order i should install the various drivers (if it matters)
Im installing them onto Win7 64bit.
Thanks in advance any swift advice would be great.
Brian
you only need the lan drivers,intel rapid storage drivers and the realtek sound drivers off gigabytes website
Oh, thats ok then, im surprised i dont need the chipset drivers. Intel Management Engine Interface and Intel INF installation - I have no idea what they do, but i allways that that chipset was to do with the CPU.
Thanks for the quick reply ill get them down onto a USB stick and in.
the intel rapid storage drivers contain those aswell so you wont need them,you can install if you want but no real need
