GA-P67A-UD3P-B3 restart loop
23 Mar 2006
help!
I got all my new hardware the other day but have had nothing but trouble.
The majority of times I turn it on and within 10secs it turns off and then back on again, it will do this repeatedly. I've only managed to install windows and boot into it twice!
A quick googling reveals a "gigabyte restart loop" but nothing is really helping. I can't even check my bios version easily as mode of the time nothing appears on the screen.
Anybody got any ideas? Really getting annoyed with this now.
Can you try running with only one memory module, just in case you have a faulty one, also double check there in the correct slots, Usually 2 & 4th from the cpu socket.
