ga-p67a-ud4 voltage reporting
4 Apr 2003
Manchester
What are you using to read voltages on this board. CPU-z and cpuid HW monitor don't appear to read the right results (report 1.08 v when bios is set to 1.31 with load line calibration on). OCCT reports 1.42 V. Bios repots 1.36v
You must have the B3 revision. HW Monitor will read the correct CPU voltage but it may not appear in the list as CPU volts it may just say CPU.
Ok I see it under cpu. Reading 1.28v which is similar to what hwinfo32 is reporting as vcore.
I do indeed have the B3
Thanks
