GA-P67A-UD5 problem.
12 Feb 2011
Hi guy's,
i keep getting this message on my new pc. Power surge on hub port (usb).
All usb ports seem to work. Also i can not get into the bios- delete does not seem to work.
Please can anyone help?
Use a PS/2 keyboard if you are unable to have your keyboard identified by the BIOS - not seeing the del key press. Or update to the latest bios in OS.
Thanks for the reply 1DAY. I have managed to get into the bios with my usb key board, had to tap delete like mad and it only rarely works. Still can not sort out this Power surge on hub port fault.
That could be because you have the USB hub connected to the specific USB port that acts as a charger.
