GA Z270N-Wifi but no CPU temps?
1 Feb 2006
Hi
I've just put together a Mini ITX build using
Bit Fenix Mini ITX case
Gigabyte Z270N-Wifi mobo
i7600K Kaby Lake CPU
bequiet Silent look 120mm AIO
MSI 1070
All working well but the mobo has two fan headers - CPU fan and SYS fan.
So I connected the pump to the CPU fan and the twin 120 fans to the SYS fan header. All working but I can't seem to find a CPU temp anywhere.
Open Hardware Monitor is not reporting any CPU temps at all. They just don't appear.
This is really confusing and worrying.
Also there is a front and a rear fan in that case and I don't seem to be able to connect them to anything. All the fan splitter cables that you can buy want to connect to a Molex connector? Why no SATA versions of these?
Mobo Bios is as up to date as can be. Win 10 X64 Pro install.
Anyone any suggestions ?
Hi
Yes Real Temp reports temperatures.
I don't understand why the bequiet AIO doesn't have any software to use with it. There is none on the website. Must just work of slowest speeds necessary
In the BIOS under the smart fan section set the cpu header that the AIO pump is connected to to full speed.
I assume the AIO fans are connected to the pump also?
