- 22 Mar 2014
Hi everyone.
I built a new Photo / Video editing machine just before christmas.
I had a few issues to start with but once setup everything has been running fine.
About a week ago I had a series of BSODs and when I checked
One of my ram modules had failed.
I have since got a replacement under warranty but I am now having stability
issues with all four ram modules installed.
With All four modules installed I cannot get the system to run stable and shows errors with prime95 and on test 7 of memtest86, It does this even at base spd settings.
If I only have 2 sticks installed the system is stable with xmp enabled and there are no errors with either memtest86 or prime95.
I have tried upping the voltage from 1.5v all the way to 1.65v and it still fails.
All voltages are set and timings set correct.
Has anyone had issues like this or can anyone shed some light on the problem.
For information the system spec is as follows:
Gigabyte GA-Z87X-UD3H rev 1.0 BIOS F8
Intel I7 4770K CPU
32GB RAM - 4x8GB Corsair Vengence Pro 1866 C9 (two kits)
Corsair H100 Cooler
Be Quiet 850W Power Supply
Gainward Phantom Geforce 770GTX 4GB
500GB Samsung 840 SSD
2x WD Black 1TB Sata Drives (Raid 0)
I am really at a loss now so any help would be great
Thanks in advance
Mark
Intel I7 4770K CPU
Corsair H100 Cooler
Thanks in advance
Mark
